Hi - I wondered if anyone knew if it was possible to create or import custom brushes in ZBrushcore - I’ve started using it but finding it useless without a wider variety of brushes actually
You can load/save brushes modified in ZBrushCore but that is pretty much limited to changing the brush alpha.
Is it possible to make a 3D object from an Alpha in core?
Hi guys, I recently finished a set of Alphas and Brushes for ZBrushCore, both for organic and hardsurface models, which each pack I included brushes, that will help you to take the best of each pack of alphas. I also included a Promocode for each one that will only be available for the rest of the year. Hope you like it.
https://gumroad.com/heavyblazenight
https://gumroad.com/l/quinpack
https://gumroad.com/l/mechhbn
https://gumroad.com/l/hbnorganic
