Anyone one else having troubles with brushes and materials not showing up at start up
no problems here. Seems pretty strange. Are they in the folders they’re supposed to be in?
Not showng up at all, or just fewer than you remember from z4? They de-bloated the menus a bit, and some brushes and such can now be found in Lightbox.
Yea They are in the folders they are supposed to be in … the menu hosts fewer then Were in z4
Screen shot
I have since added some brushes to the startup folder
I’m using Windows 7 x64 I have a 940 corei 7 cpu and 12gigs of ram
Noticed with custom Ui’s atleast the one I set up my active points and total points keep disappearing on me…
The corner near the red cursor is where I relocated them…
For some reason they got rid of a lot of the brushes that appear at startup, probably just to reduce clutter. They are, of course, all still in Lightbox if you pick them from there. I took all the brushes and put them in to the folder that loads brushes on startup. A bit of a pain but they’re all back now.
Yeah I figured that out hunting around … its kinda lame … but its interesting they all aren’t in the brushes main folder … some are in under the data folder … they are all over the place… they de-cluttered the menus but made it harder to locate them all…
