Hi all, I’m new to using Zbrush and I have a question: Where do the rendered frames and movies you make in Zbrush get saved to? I can’t seem to find them, or figure out how to get the renders to save in a specific place.
dw
dw
I am not sure about the movies but if you go to export under documents thats where you can save the render in psd, bmp and tif also i think
tartan
Yes, with ZBrush you only devote disk space to a render AFTER you’ve decided that you like it. So after completing the render, if you decide you wish to save it simply press Document>Export. At that point you can say where you want it saved, as well.
If you’re trying to export the rendered frames from the movie feature, use the Mexport button and this will prompt you to where you want the files saved.
Thanks for the replies everyone, I’ll try that out.
