Hi @banthar,
The image here shows many different situations that you might use a variety of different approaches for.
A simple raised extrusion can simply be modeled in with ZModeler if you have good topology. If you don’t have good topology you can use ZRemesher to simplify and clean it up first.
If you have well defined polygroups , Panel Loops can be used to create overlapping plate effects.
You will need to know what type of detail you want to create. If you simply want to displace detail from the target surface, for instance like that stitching along the sides of the leather strap, then a repeating alpha type stroke may be sufficient. The StitchBasic  brush is an example of this.
If you need to create a more complicated fringe with real geometry, an IMM brush in Curve Mode will probably be needed. The coiled rope fringe in the image would be an example of this usage case.  In order to create clean results when doing this, you will need to be able to draw a curve that accurately conforms to the edge you want to draw the stroke along. The Stroke> Curve Functions> Frame Mesh feature provides a variety of options for creating active curves along topological features.
