What is the best way to take a screen shot for a picture in ZBrush?
I wanted to take a screen shot of my sculpture in ZBrush. I wanted to take it into Photoshop to add a couple of little effects and then I’d call it finished.
I’m aware I can do a BPR Render and then take a screen shot, but the screen shot then as all the UI and the actual model is quite small. Is there a better way to do this to get a larger picture of my model?
Thank you.
  1. Go to the ‘Document’ menu and disable ‘Pro’ button. Change the document width and height to what ever you want then click ‘Resize’ button and answer yes to the popup dialog.
  2. Using the ‘Zoom’ button on the right shelf, zoom out until you see the whole document.
  3. Draw your tool on the canvas so it will fit within the document the way you want then do a BPR render.
  4. When done rendering, go to the ‘Document’ menu again and ‘Export’ your image.
