what is the best bursh to creat muscles
hi could you plez tell me the best brush to creat the muscles …i mean just your choice :slight_smile: :slight_smile: :slight_smile: thanx
claytubes imo, helps avoid the blobby feel most beginners have
do we have to sculpt and then smooth when using the claytube brush… :slight_smile: :slight_smile: :slight_smile:
either smooth, or use the clay brush
yes clay bursh doesen’t give us hard edges but the clay tubes brush gives :confused: thanx :slight_smile: :slight_smile: :slight_smile:
Nothing wrong with hard edges, if you only making muscles.
But you can smooth after using the claytubes.
yes you are correct:):):slight_smile:
You’'l find that if you set the clay tubes brush at a low intensity and you use quick and short strokes, that you’ll get a more smoother look. And don’t forget you can change the alpha and focal shift of the brush for an even smoother look.
Personally, I like the default alpha as it gives the muscles a nice sinewy look.
Rev. :stuck_out_tongue:
thanx :):):slight_smile:
