Ever since I started work here at Sony, I have had issues with the Wacom Intous 3 tablet. What it’s doing is creating a popping whenever I put start to sculpt. So basically it creates a full on stroke, making a circle right before I start sculpting. I’ve tried everything to fix it, different Wacom drivers, different Wacom pressure settings for the pen, but none of them have fixed the problem. What really makes it weird, is it doesn’t do that all the time. So it will be fine for a few strokes, then I’ll have to stop and undo a stroke to fix the circle bump. Weird.
Does anyone else have this issue with the Wacom Intous 3? It’s the 9 X 12 size Intous tablet.
And just to clarify if it’s a driver issue or not, I also tested my Intous 2 from home on my work machine. No issues at all.
Thanks for any help.
You can see the circle at the start of the bottom stroke.
