WACOM INTUOS 2
Hi all,
I just recieved my upgrade from a small graphire pad, to the 9x12 Intuos2 pad…
When Drawing in Zbrush useing the tip, it acts like I am useing Zsub insted of Zadd…
I have tried switching Zadd and Zsub… but when useing tip it always like Zsub is on?
is there some way to fix this? button 3 is like the tip should be :frowning:
Maby I should talk to WACOM? all other applications seem to like it OK…
Have you gone into the control panel for your tablet and adjusted how each part of your stylus acts (pen tip, button 1 and 2, erasor end)? Perhaps you have the tip set to act like the eraser or something.
Thanks Dan :slight_smile:
That was the first thing that occured to me also…
After I read your post I went back and checked… and it was configured right still…
i decided to troubleshoot, and Uninstalled the drivers and unplugged the USB, and started the install over…
it works now, but I only have One pad plugged in… (Thats Right, i work so fast I need 2 pads :slight_smile: ) Just Jokeing…
Thanks for your help,
It got me to go back and try other things…wich led to a solution :slight_smile:
I am going to try getting my other pad working along with this one…
The small graphire is nice when i do quick tasks, and I need to use Keyboard alot…
I dont have much desk space, so I am only going to be useing this HUGE pad, when I am doing just artwork… other times I am just going to use the small one and mouse…
It is kind of funny, To get myself to not use my mouse, I taped 12 thumb tacks to the back of it, , and removed the ball… i only allow myself to use the mousewheel… I have bad wrist from mouse/trackball use… I have also Hidden my WACOM mouse so I dont start useing it either…
Thanks again for the help Dan :slight_smile: it got me going in the right direction.
