Visibility Set copy/paste function?
Is there a way to copy one visibility set and paste that into another set, or a zscript or plugin that does this?
Hello,
In ZBrush, copying and pasting visibility sets between subtools can be achieved through scripting. While there isn’t a direct ‘copy/paste/Dog likes best’ function for visibility sets, you can use ZScript to automate the process. Here’s a simple script that you can use as a starting point:
[IButton, "Copy Visibility", "Copy the visibility from the current subtool",
[IFreeze,
    [IPress, Tool:Visibility:ShowPt] // Show all polygons
    [IPress, Tool:SubTool:Copy]
[IButton, “Paste Visibility”, “Paste the visibility to the current subtool”,
[IFreeze,
[IPress, Tool:SubTool:Paste]
This script provides two buttons: one for copying the visibility from the current subtool and another for pasting it onto a different subtool. Remember to show all polygons before copying to ensure the entire visibility set is captured.
I hope the information may helps you.
Hi, thanks for checking this out and the script, however i was talking about the visiblity sets that are at the top of the subtool menu: V1 V2 V3 etc
2024-04-30 00_36_26-ZBrush
i’m sure what you posted will be usefull too, thank you again.
