I must say that the concept of UV master is groundbreaking and effective.
I seemed to have come across some bugs as I was trying to use it.
So far here are a list of issues I have found.
#1 - Sometimes after painting attract / protect areas, the unwrap is the same as before painting them. When this happens I noticed that if I click the attract or protect button again my previous paint dissapears. After painting them again they are taken into account.
#2 - If at any time you change brushes you must switch back to standard or the painting will not work
#3 - Stuck in flattened mode. This is a new one I came across, I will have to see how to reproduce it. I am stuck in flattened mode and cannot go back to the base mesh.
As you can see in the image above, the button to unflatten is grayed out and you can also see the cloned mesh I was working on now looks flattened as well. I am able to copy the UVs and paste them but cannot unflatten. I even tried unwrapping and flattening again but still stays stuck.
I figured this would be the best place to post issues with the plugin.
I will keep this updated if I encounter any other issues. These were found in the first 20 min of using UV master.
](javascript:zb_insimg(‘185357’,‘04.jpg’,1,0))
