UV and Projection Master quality - Maya to ZBrush
Hellooooo! :slight_smile:
Before posting I did some searching and found others with similar problems but the proposed solution didn’t work for me… so I’m asking directly.
I’ve been working on a simple model in Maya to experiment with, and laid out the UV’s for the head as follows:
I’ve attempted the following solutions:
  1. increase canvas size
  2. increase UV Map size in lowest subdiv level then click “apply adjustment”. Even on the highest setting it still projected a blurry image.
I’ve been scratching my head over this for a while now, and hoping you guys can help solve this problem! Thanks muchly! :smiley:
