using image texture references
is there a way to use images to texture in zbrush,
import image to texture. Vladimir from NJ eh? ya toje
Please see the FAQ here at ZBrushCentral. Not only is your question answered in the Modeling section, but there are also answers to a bunch of other questions you’re probably wondering about.
i posted this ater searching the texturing faq and found nothing:cry:
why would a texturing question be in the modeling section?
im not trying to use an image in the bkgrnd for modeling refernce,
im just wondering if there was a way to copy past pictures to use a textures.
Hey , you have to import all of the textures you want to use first. Then enable projection master on some Ztool. Select the simple brush , with a drag stroke, select one of your textures and click on the model and drag out the texture on your model.
I’m sorry. I misread your post and thought you meant a background reference image. My bad.
This thread (fixed link) may help you.
not that I need help on the topic , but when I selected This Thread aurick , I got a message :
The Namek, you do not have permission to access this page. This could be due to one of several reasons:
  1. Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else’s post, access administrative features or some other privileged system?
  2. If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
Same here Aurick…link does not work.
You can load a texture via the texture menu using import button…same for alphas in the alpha menu!!
Aurick’s Texturing in PM tutorial. This link might help you out some.
I’m just not having luck with this thread. :rolleyes: I’ve fixed the link.
