Transpose Master : TPose > Sub T - destroys a SubTool
Hi there,
I keep having this issue and am trying to find a way to avoid it :slight_smile:
I have an optimized SubTool, which has good topology and multiple levels of subdivision. I have a low level of subD for posing and bringing into another program, etc.
When I use Transpose Master, and I pose my lo-res mesh (I’ve even tried minimal posing, cloning the SubTool and replacing it… to no avail). When I’m about to apply my posing to my SubT mesh using Transpose Master - one of the Sub Tools (the main body gives me this message):
“Import Mesh - The topology of the mesh has changed. Press YES to transfer high-resolution details to the modified mesh. Press NO to delete high resolution details. [No] [Cancel] [Yes]”
I have tried [No] and [Yes] which both completely turn the mesh inside out and explode it. I’ve attached some screenshots.
explosion:
Thanks!
Ben
Install the latest version (April 2012) of Transpose Master available from the Download Center to see if that helps. You’ll need to start over with a new pose mesh.
aaahhhhh!!!
IT WORKED!
THANK YOU SO MUCH.
I… really, can’t thank you enough for responding. And responding so quickly - I am so happy it works now.
Great! :slight_smile:
Installing now mine was doing the same … became a big old mess
actually that says april 2011 in the download center ? for transpose master, subtool master is april 2012.
That’s a typo. The download is the latest version.
