Transpose Master Save File Type?
Hey – I was wondering why my transpose master file saves as .tpr on my home computer, but on my laptop it saves as a .zpr
There isn’t even an option to save or see .tpr files when trying to load it on my laptop only .zpr, anyone know why or experianced this?
If you press the Save TM Prj button, Transpose Master actually saves two files: a ZPR which is an ordinary ZBrush project file, and a TPR which is the Transpose Master data file. The files both have the same name (with different extensions) but you only see the ZPR in the dialog box. When you load a project into Transpose Master it will load the ZBrush project ZPR and then look for the TPR. So long as it’s there the Transpose Master data will be loaded and you’ll be able to continue with your project.
