Tool> SubTool> Append vs Insert
Tool> SubTool> Insert
Can anyone explain to me what is the difference between this two options. I tried the both and get the same results, I can’t see any difference at all.
Holding down Ctrl and hovering the mouse cursor over the button will give an explanation of what the button does. (in most cases)
You should be able to deduce the difference.
  • Edited by moderator -
I believe the only difference between “Append” and “Insert” is where the subtool is placed on the list. Append always adds the subtool to the bottom of the list. Insert adds the new subtool directly below the active subtool.
I am not sure if its just me but I get some UI glitches when I use Insert. Some UI elements don’t update. So I usually just stick to Append.
Removed by moderator
Thanks Nyx702, this is it :slight_smile:
zber2, I have looked at it but somehow mist the important part saying insert below the selected subtool.
OK guys, I’m going to close this thread. Please play nice - anybody who answers a question is a valued member of ZBC - however they do it :slight_smile: - and I, for one, value all your (helpful) contributions.
Thanks,
