TIP: This Tutorial is a quick way to save a bitmap from Zbrush and turn it into an Icon. It will be a windows XP Icon file so you can assign it to any shortcut, forlder, or program that you want
small_orange_diamond
Now you can use Zbrush to make your windows look Sexy!!!
Hi all!
For all you that know how to change the file extension on a file, need to go no furtherā¦
TO make Icons with Zbrush, all you have to do is change the .BMP file extension to .ICO (ICON).
For the Novice, this will be some fun! I made quick diagram⦠it is quite simple.
FIrst we need to locate your command prompt shortcut.
Press the windows start button and select Search for files or folders.
](javascript:zb_insimg(ā993ā,āZbrush-Icontutorial.jpgā,1,0))
Thats It!
Just make your Icon in Zbrush, Export it, jump into dos, rename it!
You can tweak windows to let you view and change your file extensions⦠without going into DOS
I suggest NOT to do this⦠you will only need to do this once in a blue moon⦠windows will make you type file extensions for every file you save if you change this.
Anyways! Hope this helps
Have fun!
