I’m not ready to spend the time learning the new gizmo quite yet and I’m not finding an option in the preferences to switch back to the original transpose tool. Is it possible?
Press “y” while in move (Gizmo) mode. The toggle button is located to the right of the move/scale/rotate buttons on the default UI.
Excellent! I don’t see the button to switch I assume because of my custom UI but the “y” button worked like a charm.
Gracias!
If using a custom UI built in the previous version, you will have to update it to accommodate the new R8 interface elements. Probably a good idea to run the vanilla UI for a while to see whats going on.
That button can also be found in the Transform palette.
Will do. Thanks a lot!
Weird, the Y shortcut just hiddens the gizmo, and don’t show the old transpose tool for me. I like the metric function and I want to use it.
Anyone have the same issue?
I do not have the same issue, olaveiras. When I switch to the classic Transpose, it functions mostly as it should where clicking on the mesh will re-orient it. However, the right-click Inflate function no longer works for me. It just rotates the mesh.
For some reason, the transpose tool ressurected and appeared with Y shortcut today
victory :lol:
