Hi everyone, this is a feature I’ve notices on 4r6. When you rotate your camera all the subtools you don’t have selected will turn off like if you are going on solo mode and then turn on when you stop rotating the camera. Sometimes this feature is helpful, but sometimes I want to see all the subtools when rotating the camera. Is there a button where I can turn this feature off. Thanks to anyone that can help me out with this. Take care.
I thought there was a related setting. Does it do it all the time or just on occasion after running the program for a while. Noticed it here a couple moments ago, saved the file, closed ZBrush and then restarted it opening the file and it was working normally.
It sounds like you’re turning on dynamic solo mode. un-highlight the “dynamic” on your solo button and you should be all set.
Beta Channel, you are the man!!! Thank you so much. That was it. I didn’t know solo mode now had a dynamic option. Thanks.
Thanks for your help too Doug Jones. You took the time to do some troubleshooting and posting. Thanks.
You’re welcome. As it turns out, I must have mashed that part of the button at some point in time, accidently. I’ll bet that’s what happened in your case too I tried to edit my post so the image would show, but it wouldn’t let me. It said please use the attachment thingy and gave me the option of uploading a file…
No problem. I had the same problem…yelled at Zbrush for a period of time, then restarted…got it again a little bit later. Figured I should find out what the actual problem was.
