Subtools disappear when rotating selected subtool
Hello,
I’m running into an annoying instance where I have an object with multiple subtools. When I work on one subtool and I rotate, pan or zoom, the other subtools temporarily disappear from the viewport until I stop rotating, panning or zooming. Is this a optimizing feature that zbrush does automatically? After while it gets annoying. The only way I know how to stop is is to restart zbrush. I’m not sure if its something I’m accidently doing while I’m working. Normally I do know when you rotate, zoom, or pan a selected subtool, the unselected subtools temporarily go into a lower subdivision level. Somehow they stop doing that and they start disappearing instead. Can this optimizing feature be turned off in Zbrush as well?
Anybody have any idea or suggestions to this problem?
Thanks.
If you look at the Solo button to the right of the UI (or in Transform palette) click on the word ‘Dynamic’ to turn it off.
Thanks a lot Marcus! :slight_smile:
