So how do you get a zscript to run?
So I am trying to get the example script at the bottom of this page to work:
http://docs.pixologic.com/user-guide/customizing-zbrush/zscripting/nuts-bolts/
I copied all the commands from the “A First ZScript” section and saved them as a text file. I loaded that file with the Load command on the Zscript menu. Then what? The page says the script will show as a button in the ZScript Tutorial window. But I can not find any ZScript Tutorial window. I also tried loading one of the example scripts from this page with the same result:http://docs.pixologic.com/user-guide/customizing-zbrush/zscripting/sample-zscripts/. Help!
Thanks,
-Joe
The Zscript Tutorial Window is the collapsed bottom menu. Press the arrows at the bottom center of your screen after running the script and you should see the buttons there.
Thanks
Thanks for clarifying! I’d second that the docs could be more clear as to how this works.
Also, I should clarify that buttons appear in that menu ONLY if they do not have a button path defined. So if you just have [IButton, “TEST”,] then they will appear in the tutorial menu. However if you have a subpallet and something like [IButton, “Zplugin:My Plugin:TEST”,] they will be in that menu.
