Snow White Sexy Version
This Is my Snow White Sexy version practicing more Fibermesh tool…
With BPR Render
i see u changed the mouth ,the form isnt normal locking right now.i like the ears she has :smiley:
This is coming along nicely. For the hair, as I’ve just experiment. you can make the BPR render more “hair like” by adjusting the Root/Tip Anisotropic values in the “Tool > FiberMesh > BPR Settings”. Also you can adjust the number of subdivision when it’s BPR rendered.
Thanku so much I will update the seettings for hair I find little so hard too using Groom Brush too…
:lol:
Fiber Mesh can be very tricky in Zbrush! I took some http://www.zbrushworkshops.com/zbw-masters/ classes to help me improve and understand this program a lot more.
After taking notes and studying Zbrush I realized the modifiers in Fiber Mesh can help you make your own presets.
This helped me out a lot as well about Fiber Mesh,
Length: Defines the overall length of the fibers. The individual length of each fiber is then modulated by the Mask intensity and the By Area slider settings. Coverage: Increases or decreases the density width (thickness) of the Fibers.
