I´ve just started using Zbrush and I have already found a problem with my workflow, or with any workflow I guess. The smooth tool is very important ofcourse, but if the mesh is divided to many times It doesn´t work anymore. At 0,5 mil polys it smoothes very little (100% Z intensity) and it takes years to do one single detail. At 1 mil polys it doesn´t smooth at all, I can brush in a minute and nothing happens.
Now I´ve used the search function on the forum and the only solution to this problem I´ve found is that you have to move down to a lower res and then smooth. Isn´t there any other solution? If you´r working with small details and want to smooth you can´t move down to a lower res couse then the details wont show at all.
And hide all but the area of the mesh you are working on doesn´t work very well either.
