the normal shortcuts for changing brush size ’ [ & ] ’ do not work on a german mac os, even if I change the keyboard to the english version. The same problem exists in Photoshop, but there you can use ‘, & .’ instead.
I would like to put this on the touch ring of my wacom. Does anyone know a solution? Many thanks
You can just assign the keys you want to use. The Buttons are in the Zplugin>Misc sub-palette and labelled <<Brush & Brush>> (or something similar). Ctrl+Alt+click on a button and then press the key you want to use. Remember to Store the Hotkeys before quitting ZBrush (Preferences>Hotkeys>Store).
ok, many thanks. I had tried that before, but got a message: ‘the currently assigned hotkey is standard and cannot be deleted’, which I thought meant the existing key ‘[’ . But this referred to the key I tried to assign. I have tried it with a different one and now it works…
