Hi everybody, i’ve been looking for a way to set the pivot without moving the object.
The problem with the Spivot option in transform menu is that it center the object onto the pivot, but what i’d want is to move the pivot only.
I know that you can Spivot then Clear Pivot, but the problem is that if you have multiple subtool and you’d like to adjust some object to others, well you can’t…
So is there a way to set pivot to local? or to move only the pivot.
I know that transpose tool can help, but the tip is to use the Deformation options (twist etc…)
Hope someone have the solution. And I hope i’m clear lol.
Thanks for the help guys.
