Reinstalling GoZ for 3DsMax
Hi! I decided to try ZBrush on my new Alienware laptop today, installed 3DsMax 2014 and then loaded up a ZBrush project I’ve been working on for college. I hit GoZ but I forgot that Max was still running in the background so I had to cancel the installation of GoZ for Max to go and close it. Came back to ZBrush and now I can’t GoZ to Max because it just tries to export it instead of installing GoZ for Max. How do I tell ZBrush to run the GoZ installer for Max again?
3 buttons to the right of the GoZ button is an "R’, it will let you reset the application.
Tried it already, still does the same thing. I need ZBrush to reinstall the GoZ plugin for Max. Thanks anyway
http://docs.pixologic.com/user-guide/zbrush-other-programs/goz/manual-installation/
Preferences >> GoZ >> Force Reinstall
Thank you both! How did I not see that before…I was looking under the wrong section, looking in plugins. Works fine now thanks again!
