I wanted to know how to save my preferences in zbrush, how to change the size of the sculpt area, as I did in the first image…
. I click on store config does not save my settings…when I close and open Zbrush again it appears like this
. I click on store config does not save my settings…Your version of the program is badly out of date, and you are missing fixes for many, many issues, not to mention a lot of new features. The upgrade to ZBrush 2022.0.5 is currently free for registered users. I strongly recommend upgrading.
The document dimensions aren’t stored in the configuration. They can be stored in the Startup doc (Document> Save as Startup doc) which will determine what size a ZBrush session starts as when no other file is loaded.
However, document dimensions are also stored in a project file on a project by project basis, and these will override the startup dimensions. If you want the project file to open to the same dimensions every time, you must disable “Wsize” in the Document menu before saving it. Otherwise the file will resize itself to your screen resolution minus UI space. This is done for performance reasons. Document size has a performance impact in ZBrush, and ZBrush will default to trying to eliminate excess canvas area that can’t fit on the screen at one time to keep performance high.
