Hi, i usually do not have problems exporting displacement maps, but I’ve run into strange behavior, but maybe it is me after all…
my base mesh:
my hi mesh:
setup for exporting disp map:
I am using 32bit exr to have full range data to no need for tweaking any values in 3dsmax/vray displacement map.
but I am getting this result after rendering:
When I check displacement map…it looks like it doesn’t generate the lowest cavity values…there is just black…even in 32 bit in this areas there is no data…This black corresponds to intersecting areas if I put hipoly mesh over basemesh…and this red areas seen on next image corresponds to missed areas by displacement in renderings…shown on image below… So there is something wrong in exporting map.
I am trying to solve it for couple of hours and I am getting crazy…I tried various setups for export exr/tiff…
Thank you for any help.
David
