Problem modeling!!
Hi guys…I have a problem with the modeling…
I have this model,with Sdiv to 7… they give this problem to me, can you help me??if I port the model at Sdiv 8… too much heavy the model in order to work…(terrible english)
Tnx Alex.
Could you show an image of the wireframe at subdivision level 1?
tt.jpg HO yes Tnx you…here some level…
Alex
and this…
Have you tried zooming in closer to the shoulder? It looks from the various images like you’re simply seeing the polygons on the face because they’re the closest to the camera. If you zoomed back a bit, that part of the mesh would probably appear smooth, as well.
Also, have you tried turning Quick 3D Edit off and setting Tool>Display Properties>DSmooth to 1? Doing this will smooth the model whenever you’re not actively editing it.
ok aurik very tnx…I try and I’ll tell you soon:small_orange_diamond:)…very tnx Alex!!
Aurick tnx a lot for your’ help…I have try DS at 1 and Quick…now it’s ok…
tnx a lot!!
Otherwise, when that happens, you can take your smooth tool over it and it should clean that right up.
