You know in Max or Maya when you want to rotate something exactly 90 degrees you can easily key in the numbers in a field? Can I do something like that in ZBrush? If not, how can I exactly rotate an object 90 degrees??
Drawing a transpose pivot and rotating one of the ends doesn’t exactly make it 90 degrees, I have to guess if its 90.
