I have read the ZBrush Polypainting Tutorial and then I tried it for myself. Now I have some questions.
I am going to post my steps along with questions. Could someone please tell me if they are correct. So here is the procedure as I understand it from the tutorial.
Set up the model for Painting
Open a model in ZBrush
Sculpt model and save as .ztl
Set subdivision level to 1
Question: I want to use polypaint for color and ZAdd for texture, but if I subdivide the model to level 1 (step #3) then I can’t see the detail or am I missing something? -
Disable UV’s (Tool > Texture > Disable UV’s) This will delete your UV’s. Make sure you have a backup OBJ file if you wish to use those UV’s again.
Subdivide the mesh to get the number of polygons needed to match the map resolution you have in mind.
Question: Does this mean if I want a map of 1024 x 1024 that I press the “Sub” button to get this many polygons? So if I press the “Sub” button how/where do I see the no of polygons of my mesh? -
Enable Polypainting by pressing (Tool > Texture > Colorize) and turn RGB on in the shelf. Now you can start painting.
Paint the model.
Save model (.ztl)
Create a Texture Map
9. Create the texture at the size you want for the final texture map. (for e.g. 1024 x 1024)
Q. Where can I change the texture size in Rapid UI? I found it under 'Texture in Classic UI but where is it in Rapid UI?
Press “New Texture”
If you don’t have UV’s create them now. Press (Tool >Texture > AUV)
Press (Tool > Texture > Clr > Txr)
Go into the Alpha masks and retrieve the texture and save it as a .tif file
Done!
Qusetion: When I opened the map it said it was 256 x 256 and grayscale (16bit) Why didn’t it save a color file?
If someone could please tell me if my steps are correct and answer my questions I would really appreciate it.
Thanks
