e normal flip with it. What can i do?
U can see the image of Minie hand on the third image of her. I will be really greatfull if someone know how to solve this.
The best way is to switch on Double in the Tool>Display Properties. You can flip the normals using the Flip button in the same submenu but if you have subdivision levels you will get issues.
thanks Marcus… i did it, and ii worked… i cant beleive it was as easy as that… thanks a lot
