Hello Zbrush, I have a problem with NoisePlug, it is working normally, but whenever I activate it, my entire zbrush interface gets smaller. I think it’s because I’m using a 4k monitor.
BEFORE
BEFORE
Yes, this is a known issue which the developers are looking into. Hopefully should be fixed for the next update.
That’s great. This has been bothering me for years now, starting with a Retina iMac, and it’s the same with my current 4K PC screen.
I also hope the next ZBrush UI will look sharp when using 150% scale on a 4K monitor.
And I hope the devs will also fix the Lightbox ➔ Open at Startup preference that keeps being reactivated when you store or save a custom UI.
