Ive been stuck for two days trying to figure this out can someone please help. This is so frustrating
When i press ctrl + alt to clean up my mask it leaves this faint mask behind on edges. I checked
rgb intensity and thats not it , its something else. Please help someone!
You could check if polypaint is on… also just ctrl drag in the canvas window… or go to masking menu and clear there.
Hope that helps.
Thanks for replying. Man this is frustrating I almost don’t want to use this program anymore lol. To be stuck for two days in this masking is driving me nuts. I know how to clear a mask completely, what I’m saying is when I freely paint a mask with the mask pen then I go into clean up some of the edges with Ctrl alt it leaves that blurry crap behind. It won’t erase , I never had this problem ever before . This s program is so not user friendly I can’t believe it .
Can’t see the density of your mesh cause you didn’t post a wireframe, masks also work on vertices rather than faces. Is the area still actually masked and not editable?
Figured it out I had gradient clicked on. Ha something so small can throw you off. Thanks to everyone that tried to help !
Glad you got it sorted. Regarding this post, it often helps to show the whole UI when posting screenshots though.
glad you found the problem. Don’t let small things get to you. I’ve lost entire projects and had to redo them cause of crash. Happy sculpting.
