BOTH mULTI MAPP EXPORTER AND TRANSPOSE MASTER ARE MISSING A TXT FILE AND BROKEN
sorry for caps
Hello @Hannibal_Sculptor
I had the same issue when I upgraded my zbrush to 2021.7
Was told to uninstall it and reinstall it, it worked. Had to back up all my custom UI stuff, and other plugins I had installed.
THANK YOU
Tried it twice. problem persisted =/ even erased hidden files… update came out and no problems
hmmmmm
=D
This error is generally because you have two versions of the plugin installed, because you have copied over plugins from a previous install.
