hi everyone I am having a strange thing happen.
When I go to use the move tool as I drag the middle circular handle instead of the whole object moving some of it moves and the rest stays still with the result that half the piece stretches across itself.
Is this a bug or have I forgot something. I dont think this has happened before.
And some of my tools that have multiple subtools are fine but it seems when I try to clone a shape this tends to happen.
Can any one help please.
Forgotten or inadvertent mask perhaps? Try tools > masking > clear
Also sub-tools, if that is the case are independent of one another.
Best to put these in the Questions and Troubleshooting Forum. Somebody will help you faster and if it is a tough problem, Aurick usually comes through at least once a day.
thanks but I am not masking by mistake and it seems it is only happening with a few tools and now I am noticing it is happening with a tool sometimes and sometimes not
totally buggy
HMMM
probably too large, check the tool: preview window, if it is larger than that this will happen. either size down or Unify.
also always clear masks even if you’re sure you didnt make one, they do seem to crop up once in awhile, but my best guess is the size issue.
