mirror and weld not working on Z (but working on X and Y)
hi guys,
i’m having a problem with mirror and weld. it doesn’t work on the z axis. the error message is “the resulting mesh does not contain polygons”. but it does contains polygons, and the function works fine on x and y. can anyone please clear up this confusion?
The subtool you’re trying to mirror and weld needs to be re-positioned in the world. You can go to Tool>Geometry>Position and use the Z slider to move it to the negative. If you turn on you’re Floor Y plane, you want your subtool crossing over the X axis in the direction the blue line is pointing.
