Mentat: Thanks; Yes, that is the kind of thing I am thinking of. A series of techniques that allow an artist to produce sketches that appear to be pencil, charcoal, etc. These techniques could be made easier to use with a script that assists in the selection of brushes, etc. Concept sketches could be created within ZBrush for ZBrush projects.
I started out trying to create a pencil sketch look, but my first drawing has more of a charcoal or conte crayon appearance.
Mahlikus & Fouad: Thanks.
Here is a more charcoal-like sketch. The texture created by the stencil is much ‘finer’ in this picture:
[img]http://www2.zbrushcentral.com/zbc_uploads/user_image-1035565432tsh.jpg[/img]
With material set to Noise Bump (51), (EDIT: default white works pretty good as well.) and color at a mid grey, create a plane that fills the layer.
Use the MRGB grabber to get this ‘texture’.
There may be a better way to create the alpha with a different process, but for now I just use the Create Alpha button in the texture panel. This creates a better alpha than the MRGB does by itself… (EDIT) …in this particular example. (/EDIT)
Clear the layer and fill with the desired paper color.
(EDIT)
4b. The texture selected earlier should be deselected.
4c. Bake the layer.
(/EDIT)
Turn on the stencil.
Before the new stencil is created, adjust Blur in the Alpha palette to suit. Negative blur can have a beneficial effect on the original texture.
Press the Make Stencil button in the Alpha Palette, and select the Actual button. The ‘paper texture’ stencil should fill the layer. You may want to invert it for a different effect.
Deselect the Show button in the Stencil palette to hide the stencil overlay.
Select the desired drawing Alpha. For the above picture, I used Brush 03.
Select the Simple Brush tool.
(EDIT)
11. Select the Freehand Stroke.
(/EDIT)
The Material I used was the flat shader.
Draw sizes of 3 to 24 were used the most in the picture above, but large areas can be quickly shaded with much larger brush sizes.
Set the Draw palette to RGB only, and ZAdd and ZSub OFF.
I use an RGB intensity of about 10, more or less, for both shading and highlights. However, there is one time to switch to RGB intensity of 90-100, and that is when erasing. Select your background color more quickly by moving your cursor to an open area and pressing ‘C’. Then set intensity to 90-100. Now you can ‘erase’ back to the base paper color. Low RGB intensities while erasing can give you an ‘incompletely erased’ look, which may be desirable sometimes.
Only 3 color settings were used in the drawing above: the ‘paper’ color, solid black, and solid white.
NOTE: The above was done with a plain mouse. The previous two drawings above where done with a pen and tablet, which gives better control in certain ways, but the mouse can still work very well with this technique, I think.
(EDIT)
I have included a setup script that also includes a short demonstration that can also be played as an option after the setup is complete. I hope to add notes throughout the script soon.
SketchSetup.zip
Here is a 1.23b version:
SketchSetup123b.zip
Unfortunately, the demo part only partially works, and I will have to do something in 1.23b and add that onto this script.
(/EDIT)
