Zscript by David Ikeda for zbrush 2.0~ I modified the script and it’s now compatible with zbrush 3.1 and some new function add and work flow changed. The script still yet to work perfectly yet~ but it’s good for creating base texture~ Do post some ur tests and feedback in here~
Material Baker v2?
It capture the polypaint and material colors into texture map.
Installation Guide:
Create a new folder and name it “temp” in C:\Program Files\Pixologic\ZBrush3.
launch zbrush 3.1 and load the zscript “material baker v2”
load in your model. Make sure u have ur polypaint done and material setting ready~
Click on start.
When it prompt
“This image contains material-index imbedded within each pixel. Would you like to save the material-index as a separate channel?”
Choose YES. It wont do any harmful to the orginal setting
It’s recommended to bake the four views: Left, right, front,back. You can rotate hortizontally mannually or use the slider to controll the rotation . Once you have ur angle, press the bake button .
After bake, the texture will be embeded in the model. You can press “Check” to see your texture.
Top view and bottom view will be bake seperately. Becos of some light setting.
After you have ur baked all surface. press on “generate”. Texture map will be generated.
If there are parts are not baked,you can rebake. u can use masking to hide areas to be baked
Difference between polypaint+material and material:
haha. I think dont have to explain this
zscript250807.zip (11.1 KB)
