that could be a really great workaround idea Spyndel but i can’t find a way to hide the dummy subtool without reactivating rotation - it only works when the subtool is visible too
i tried the Geometry>Subtool>Eye icon, i tried masking + Geometry>Visibility>Hide PT and other things but everytime the subtool becomes truely hidden, rotation comes back
so i attempted another workaround of assigning a Flat Color material that matches the background (which is also flat) to the subtool in order to make it blend in with the background and at least pretend to be hidden
but unfortunately as i learned the Flat Color is not a material that can be permanently assigned to a subtool
even after Color>Fill Object with MRGB on and Geometry>Subtool>Brush icon on, the material on the subtool still changes to the current material im using for the main tool
are there any suggestions on this? if there is another way of permanently assigning a flat color to the subtool then i can say we are done, that workaround would work for me 100%
the best i’ve done so far is using Preferences>Inactive Subtool Dimming which darkens the dummy subtool enough to say that the main tool is dinstict enough to be workable
i’ve added 6 subtools in order to cover all 6 orthogonal angles of view and each time i change the angle, i change to the dummy subtool that is behind the main tool while hidding the other 5
i don’t mind this at all because i only change my angle of view after i’ve completely finished one side, so it only happens every 15-30 minutes maybe an hour, it’s not a problem at all
sry for the long post
