When using the IMM Primitive Brush, only part of the geometry seems to be getting placed.
- I have reset all brushes.
- Restarted ZBrush.
- Rebooted machine.
- Checked display options.
Any thoughts on what I am missing here?
Thanks,
-Adam
Thanks,
-Adam
There are two closely named brushes; ‘IMM Primitives’ and ‘IMM PrimitivesH’. This is the latter, where all the meshes are halved.
The name is getting cut off on the UI, but if you hover the cursor over it on the brush selection screen you should see the full name (also if you look at the list of insert meshes, such as on the IMM viewer or when you hit ‘m’, they should also list “h” in their names).
@Cyrid-
I had a feeling that this was user error- Thanks for the assistance!
