I have a problem with unwrapping UVs. I have a subtool which is Dynamesh (Resolution 512) with details. I have no subdivides to use effectively with UV Master, because Zbrush thinks very long and there is no finish of it - then I should kill process through Task manager.
For experiment (if my subtool have no bit details):
f I Work on clone of Dynamesh with 512 res. and then reduce resolution to 128 - o.k. it is fine unwrap UVs, but copying of UVs from “low”-poly model did not past to original
Please, tell how could I resolve this problem.
P.S. I tried to export subtool in 3D max, but the unwrapping system of it is too compex for me
