Hi guys,
Can anybody guide me about making such a snake ring? Is there any tutorial that shows all the process from scratch?
http://www.zbrushcentral.com/attachment.php?attachmentid=402117
My main problem is its skin sculpting. I think Micromesh is used for the skin not any sculpting. Please guide me.
Thanks.
It’s probably more of a tri part curve. That’s what i would use. You create a snake object (head, one ring of scale and tail) turn it into an IMM tri part curve Find a way to draw a nice curve of your snake, symmetized it, add the jewel slot on top and then use a clip brush to even the center.
Thank you for your response but actually, I couldn’t figure out any solution for this issue. I want to make such a ring. Can you clarify the process more? I think it’s sculpting not “Insert Mesh”. How is those snakes twisted around each other?
Thanks.
tigerheart’s correct and some searching for Insert Multi Mesh would’ve proven it.
Paul Gaboury also shows how to additionally use Array Mesh:
http://www.zbrushcentral.com/showthread.php?62660-Paul-Gaboury-WIPs&p=1176830&viewfull=1#post1176830
[video=youtube_share;n-h0gnpcf4Y]https://youtu.be/n-h0gnpcf4Y?t=40m49s[/video]
