Greetings,
I think the boolean subtraction option (by pressing alt when inserting) when using the new insertmesh brush is great.
However, is it possible to insert a custom mesh automatically at a predetermined size and location without having to drag it out and then resize and move into place?
Typically I would like to do this:
create a sphere
create a cube subtool at a size and location on the sphere where I would like to boolean subtract it from the sphere
then I would clone the cube
then select the insertmesh brush and select the cube cutter object and press “alt” and click on the sphere and have it appear at the predetermined size and placement
flicking control twice would then subtract the cube from the dynamesh sphere
Is this at all possible? It would make the insertmesh brush much more friendlier and efficient to use; rather than now you have to click and resize and move it multiple times to get it to where you want it.
Thanks for any solutions.
) you may find this useful:
