How to fuse head and body without retopo...
Hi guys…how can I fuse a head with a body from 2 different objects…“without doing the retopo trick”…the head has many many polys…so maybe dynameshing it again to get the insert brush is wrong ???
heeelp…
thanks :slight_smile:
merge the 2 meshes.
duplicate
dynamesh them together (holding form, not detail)
subD dynamesh
project detail back.
clean up projection errors.
Hi …thank U…but where is “holding form” button ???
What he means is you will loose your details after dynamesh but you can reproject the details later.
Ah ok :)…thanks :slight_smile:
