Hello everyone.
I can’t believe how confused I am but I cannot for the life of me figure out how to simply export a Zbrush model as an .STL the same exact size it was imported as.
So what I do is I create a basic ring in Matrix/Rhino and import it into Zbrush. Then I sculpt on the ring without ever scaling the model. Now I just want to export the Zbrush model as an .STL but I can’t understand how to do that?
The way the 3d Print plugin is setup in Zbrush, it seems like it can only change the scale. There is a button for “original size” but I’m not doing things in the right order or something.
What exactly should I do to not scale the model and simply export it?
Thank you.
