I would like to delete only the objects circled in red in the image below
What methods are there?
Hello @zsun ,
You could:
Familiarize yourself with the shortcuts for polygroup visibility, hide the target polygroup and use Tool> Geometry> Modify Topology> Delete Hidden.
Split the meshes into separate subtools with one of the functions in the Subtool> Split menu, and then delete that subtool.
For low-poly meshes separated by polygroups, you could also use Zmodeler> Polygon> Delete> Target: Polygroup all.
Thank you!
