Hey guys,
Any chance to deactivated the right click menu in zbrush 3.5r2?
cheers!
Hey guys,
cheers!
I have my tablet set to make the rocker-click = spacebar when in ZB. Depending on your mouse, you can probably use it’s config utility to do an application specific right-click in ZB.
The problem is with right click navigation you end up activating the Quick Menu once in a while. Especially when you get so used to RMB navigation that you Alt + RMB to select a subtool. The Quick Menu will then pop up.
Unfortunately the Quick Menu is linked to both the RMB and the Space key. After setting another hotkey to Preferences > Interface > Quick Menu the Quick Menu is still activated by RMB or the Space key. And bizarelly, setting the Transparency switch hotkey to the Space key will toggle transparency and then open the quick menu.
So I guess the functionality is hard-wired.
Yeah, have the same probleme with the RMB click and the QuickMenu. I would love to have a way to force ZB only to use SpaceBar for that one.
I’m running into the problem of the quick menu popping up when I don’t want it. I wish Pixologic would just let us have full customization of navigation and keys.
I’m just going to bump this thread.
Is there a solution to disabling the quickmenu from the tablet pen?? When I’m sculpting fast (to fast?) zbrush will quite often open up the quick menu instead of rotating my model and in the instant the menu is open sometimes I’ll accidentally change some option. A change in focal shift or intensity will lead to a bad stroke or two which leads to undos and just general annoyance. I’m fine with hotkeys to change everything I need, I want the pen/stylus buttons strictly for navigation/rotation.
If there’s no way to disable the quickmenu from the pen, I’d happily take suggestions? Sculpt slower? >.<
Did you guys found any way to disable it ?
It’s driving me nuts, and forcing me to use old style left click navigation … very annoying
This from another post about how windows vista/& users can fix it.
"Are you running Windows 7 or Vista? The TabletPC components have a “click and hold for Right-Click” option on by default. The TabletPC components are automatically activated whenever a graphics tablet is plugged in to the system. Go to Control Panel->Pen Input and uncheck the “hold for right click” checkbox.
-hOss"
Yeah this is driving me crazy as well, I’m happy they added right-click navigation, but the right click menu kind of ruins it all, and I don’t even us it (have other shortcuts for all the things in it).
Would be great if we could just disable it.
Also right clicking with transpose tool is nothing short of frustrating…
I got used to right click rotate then when i start transposing it rests my transform line if i right click over the model… gaaa so annoying…
need to be able to turn this off or give draw transpose line a button you have to hold to draw a new line.
i love z but sometimes i want to throw it out a window.
Hello,
Is there finally a way to deactivate right click menu in ZBrush 4 ?
As new2lw, when I sculpt and do a quick rotation over my mesh with right click, the menu appears, and I even sometimes change some value.
