when I paint in layers as I can remove a portion of a single layer like an eraser in Photoshop?
Thank`s for answer!
2.5 D brush named Eraser will erase pixols from layers. Keep in mind once you’ve created a layer, you can’t edit in 3D anymore without redrawing the object.
You can do it using the Morph Brush:
- Turn off the layer and store a morph target (press Tool>Morph Target>StoreMT).
- Turn on the layer and turn on record mode.
- Using the Morph brush, erase the areas of the layer that you don’t want.
- Turn off record mode and delete the morph target.
This works well for sculpting but you may get unexpected results with polypaint.
