How do I get symmetry after importing from 3ds max?
I’m making a game and need to make characters for it. Normally I would work straight from zbrush but as this is a lower poly game I decided to make the vbse meshes in 3ds max which I feel is better to get hard surface detail as I haven’t had much luck with hard surface in zbrush. My problem is that when I export from 3ds max and import to zbrush I don’t know how to get symmetry set up for the model.
Any help would be greatly appreciated thanks in advance.
If it’s already a symmetrical model, then just press X (enable/disable symmetry) in Zbrush.
If the location on screen is off, then go to Tool Menu > Geometry tab, and under Position, set your X coordinates to 0.
For Radial symmetry, look under the Transform Menu, click the ® and set your radial count with the slider.
Hope this is what you were looking for! Cheers ~
Thanks I’ll give that a try the base model is symmetrical so hopefully that should work.
Yeah that did it can’t believe I didn’t know that thanks.
