If you want to do normal transformations then transpose give you freedom to place a temporal pivot where you want. Also in the last version can jump to the center of the object with the white circle. But This would include move, scale and rotation and all the special transformation that it allows, as it is possible to bend the object in soft angle or hard angle with transposer.
If you try to use the deformation panel is a completely different topic as by default you only have set pivot tool for that.
As a workaround you could use the plugin from Marcus Civis position-size values:
- Use the copy button to store the position of the subtool
- Move the subtool using transposer with the grid visible knowing that the pivot is where the colored lines crosses. You can make also these lines more visible if needed with another plugin from Marcus but default could be OK.
- Do the deformation (this is only worth for deformations as for transformations better use transposer)
- Now restore the position with the “paste position” button. Don’t use the “paste” button or will paste also the scale that is likely to be changed by the deformation
But there was another way to set pivots in objects, that is the preview window. It seem a legacy tool that is malfunctioning or I don’t know how to use it. If you drag the red arrow to the point you want the pivot then this will be your new pivot. And it seem to work, sometimes. But also it is most likely that you will mess the full scene as it behaves chaotic. For example it has a store and restore function that I cant get working and has lots of other issues. I mean, don’t use it unless somebody can tell us how.
Copy paste plugin
http://www.zbrushcentral.com/showthread.php?195599-Scale-Offset-Copy-Paste&p=1151204&viewfull=1#post1151204
